Thanks for your help.
I am struggling to try out the 5-axis CAM feature and have a question.
I created a path using the 5-axis option with a simple pocket removal to test the operation.
When I run it, it cuts through the air, so it must be off somewhere, but I can't figure out what I'm missing.
I use Hand-made 5-axis CNC.
The machine I am using is not in the library, so I use 「AutodeskGeneric5axis (ACtable)」 with no TCP.
About post, I chose 「5ASISMAKER」 which is close in shape since there is no post.
The following video is what I tried to move it
https://youtu.be/DR9ROVBHlZI?si=KThBF-Q0iElLE3-X&t=36
I used this ↓ page as a reference
https://forums.autodesk.com/t5/hsm-post-processor-forum/how-to-set-up-a-4-5-axis-machine-configurati...
I have defined the machine configuration, but I have not defined where the C axis is placed on the A axis, so I am wondering if it is misaligned with the rotated position of the actual machine.
Is this misalignment caused by the machine's table positioning relationship not being defined correctly?
If so, where is it defined (offset in machine settings? 3D model shape?)?
If you know anything about this, please let us know.
