Fusion Manufacture
Machining pockets
4 REPLIES 4
blackprogram
296 Views, 4 Replies
Machining pockets
Can anyone help with the correct machining strategy for cutting out oval pockets in a part? I have tried 2d and 3d with no success, I am getting empty toolpath or no passes to link. Please see the attached file.
4 REPLIES 4
Hi.  In this case I'd use 2D Contour
jhackney1972
in reply to: blackprogram
You can also use 2D Pocket for these slots.  Model is attached.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
blackprogram
in reply to: jhackney1972
Thanks for your help, after downloading your model there are no toolpaths, only the setup in the left hand plane. Another persons included a model this had toolpaths with this.
jhackney1972
They were there, just turned off in the Browser.
John Hackney
Retired
