Fusion Manufacture
Machining 3D fillets
4 REPLIES 4
David_HCB
142 Views, 4 Replies
Hi all,
How are people approaching machining fillets such as these?
all to be done with 6mm ball end mill.
With 3D contours with spall stepovers and contact boundary, tool centre on boundary the top edge isn;'t machined to the line as it's "rather horizontal", bottom half of the fillet the toolpath is good naturally. I've tried bottom up also and it still struggles to come close to the top line.
Thinking 3D Parallel might be better. Two passes, one at 0deg, one at 90deg, or perhaps 2 at 45 deg to get more material machined away.
3D flow seems to do a good job of the face, particularly in the case when I say 20 stepovers, just a bit paranoid as there is no ability to say don't touch other faces, but the toolpath looks good under simulation
thanks
David
David Harrison
Harrison Classic Boats
Win 10 / I7-11700K @ 4.9GHz / 64Gb RAM / SSD's
4 REPLIES 4
a.laasW8M6T
in reply to: David_HCB
I used to use blend a lot but my goto now is the Enhanced Flow toolpath
These both need to be turned on in preferences
As you have found Contour doesn't do well in shallow areas, its primarily for steeper areas as it is a "Z Level" or "Waterline" toolpath,  in which the tool steps up or down in fixed Z level increments regardless of surface curvature
The Enhanced Flow and Blend toolpaths have an even stepover regardless of curvature and work really well on fillets
David_HCB
in reply to: a.laasW8M6T
now that sounds good - I'll have a look
seems to do some nice lines, but still hard to see via simulate whether it's going to touch adjacent faces. From what I gather it started on the bottom geometry line using the top of the radius of the ball end mill so it should be safe.
just might need to run a test piece 🙂
thanks
David Harrison
leo.castellon
My recommendation would be just to get some corner rounding tools, it will save you a ton of machining time, like these: end mills | McMaster-Carr . These tools are designed to machine those surfaces in 1 pass, if the material is harder, like for instance stainless steel, then 2-3 passes.
LeoC
David_HCB
in reply to: leo.castellon
not a valid strategy I'm afraid.
All the fillets are 3D, ie. not planar to the XY plane, adjacent faces are tangential (but not in a perpendicular sense) and sloping in all directions.
I have plenty of round over bits but they are not suitable. I have a 3 axis flatbed and the material is wood. Surface finish isn't critical as it will have a final sanding, just need to cover as much of the "shape" of the surface so I don't have large cusps to deal with between adjacent faces. Seems flow gives the best results.
David Harrison
