Fusion Manufacture
Machine view default to off
2 REPLIES 2
nbm350
120 Views, 2 Replies
When I create a new setup, the defaults make the machine visible. I always turn this off. Is there a way to set the default machine to not visible? I've tried saving setup parameters but it still shows when creating a new setup.
2 REPLIES 2
weber_dominic
in reply to: nbm350
Check if the visibility is turned off here at the bottom bar
nbm350
in reply to: weber_dominic
Didn't even occur to me to look there. Your solution worked and has been accepted. Thank you!
