Fusion Manufacture
Machine tool collision
6 REPLIES 6
NuovaOlpa
237 Views, 6 Replies
I have a problem with the machining simulation, it does not detect the collision with the structure of the machine tool when the orientation changes.
My PC system is a Mac mini pro M2.
Best Regards
Dario R.
6 REPLIES 6
TrollTuner2
in reply to: NuovaOlpa
Do you have Machine Collision Detection ON in preview Features?
If its on Maybe its a setup wrong, The vice in the wrong place, the Fixture or the tool Length.
NuovaOlpa
in reply to: TrollTuner2
Yes, the option is active
NuovaOlpa
Yes, the option is active.
rengfx
The detection will not work during linking / orientation moves, as it's not checking against full code or anything
I would ensure your retract options (G53 / G28 / Clearance plane) are what you expect
TrollTuner2
I believe it will show linking moves correctly if they are in High Feed.
NuovaOlpa
When you install the new version "2.0.18220 arm Native " of Fusion360, you have to avoid the collision problem, but it is not possible to prevent the collision of the machine with the machine rotating in the position following an operation and another.
This is a serious problem when trying to use another program.
