Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
Machine simulation X axis alignment
2 REPLIES 2
gotzym
188 Views, 2 Replies
I edited the original Autodesk YX Z 3-axis machine to fit our needs, but I can't figure out why my X-axis has an offset when simulating with the machine.
In the machine builder, the components are chosen correctly, and every movement has the right direction and amount. Every component's origin is lining up.
When I set up the machine in the manufacturing environment, everything was fine till I started the simulation.
I attached some pictures of what's going on. Could you help me? What am I missing?
Thanks!
2 REPLIES 2
emre_sahin9PU3F
in reply to: gotzym
Hello, can I examine the machine kinematics? Can you send the file?
gotzym
in reply to: emre_sahin9PU3F
HI,
Sure, thanks for the reply. I can't really find what am I missing.
There you go:
