Fusion Manufacture
Machine over holes in flat operation does not entirely go over cavity creating incomplete toolpath
3 REPLIES 3
deutirium
224 Views, 3 Replies
I'm using the flat operation to face my part because I cannot use the face operation because I require some containment and that option isn't available in the 2D face operation. I'm creating a mold with large cavities that take up most of my stock but I'd like to machine over them nonetheless. The flat operation sees this as unnecessary and so I must select the "machine over holes" options. The problem however is that it does not create a valid continuous toolpath no matter how large I set the limit for "machine over holes, even if the limit is greater than the size of my entire stock.
What I would like to do is to face the top of my part, with the exception of the 2 holes highlighted here, with tool containment inside boundary and I am unable to do that with the face operation because it doesn't provide the option for containment boundaries and the flat toolpath is glitching due to the cavity.
A very tedious and unnecessary workaround has been creating another piece of stock WITHOUT the cavities (but with geometry to select the holes I wish to avoid machining) and creating a new manufacturing setup.In that case the flat operation gives me the desireable toolpath.
Labels (2)
3 REPLIES 3
seth.madore
in reply to: deutirium
Hole ≠ cavity in part. What you are showing are not holes, but cavities/voids.
Holes = cylindrical features
The easiest thing would be to make a patch surface and include that in your toolpath "Model" selection
Seth Madore
deutirium
Thank you for the clarificatiom. A patch may be easier and quicker than creating a new stock model. It still requires creating additional geometry though, is there no solution for this through the menu of any toolpath without having to resort to new geometry?
seth.madore
No, I don't think so.
Seth Madore
