Machine export crashes with a customized machine file.
I have a HAAS V-F2YT Machine that I customized with a tr160 trunnion. I had to change the A-axis parameters to simulate and control the trunnion correctly. (The A-axis was reporting -90 in the nc code and making the tilt go the wrong way on a HAAS VF2YT Machine) Having corrected that and verifying the control was working properly I decided to export the machine so others could use it outside my facility (Programming Supplier). When I try to Export the same machine, it crashes. I tried exporting with a "generic" machine from the library and export works fine. I have uploaded three error instances but thought to come here for a possible solution.
Any ideas as to what might be happening with my custom machine? It looks like it might be the cloud translation wreaking havoc somewhere down the line.
I would send the file - but alas - I cannot export it.
