Fusion Manufacture
Machine Designer and Kinematics question
3 REPLIES 3
tgioiosa
116 Views, 3 Replies
I am trying to create a custom Machine for simulation but having trouble getting it to work correctly. The machine is the MPCNC from V1 Engineering if anyone is familiar. This design has the Spindle on Z-axis, but the XY is different than the generic 3-axis examples from Autodesk.
Both the X and the Y axes can each move the spindle/Z axis independently, and moving the Y-axis does NOT move the X-axis, and vice-versa. It seems like I need to assign the Spindle/Z to both the X and Y yet keep them from affecting each other, but if I place Spindle under Z, and I put Z under X, I cannot select Z again to also make it dependent on Y.  I guess the Z needs to be an 'OR' function of X or Y, but I can't figure out how to get this.
Anyone dealt with something like this before?
Here's a short clip showing how the axes move in relation to each other:
https://youtube.com/clip/UgkxBv8XWPSdE69FGmFfDJJPozY3jLyuIabk?feature=shared
Any suggestions are appreciated, thank you.
3 REPLIES 3
seth.madore
in reply to: tgioiosa
You're likely not going to find a suitable arrangement of axis to make simulation work correctly.
However, you really don't need it to, as your main concern is clearance of tool and XY envelope, right?
I'd just use a generic router style machine config and adjust as needed for spindle diameter and travels.
Seth Madore
tgioiosa
in reply to: seth.madore
Thank you for the response. I was anticipating that would be the answer, but was hoping there was something I wasn't doing correctly. I spent hours trying to get that to work.
It could work if Autodesk allowed the Machine Sim/Designer to respect Joints and Motion Links. Are there any plans to give it that capability?
seth.madore
Not to my knowledge, sorry.
Seth Madore
