Fusion Manufacture
Mach4 PP need to be modified so that the spindle goes to a specific position I assigned.
2 REPLIES 2
ysymidi
94 Views, 2 Replies
I recently updated the PP to the latest version.
Before update, my PostProcessor sent the spindle to G53 Z0, and then G53 Y380.
But now it sends the spindle to G53 Z0 X0 Y0
What shall I change, to send the spindle to G53 Y380 at the end of the G-Code?
I attached the PP I use now.
2 REPLIES 2
seth.madore
in reply to: ysymidi
If you create (and use) a Machine Configuration (even just a generic Autodesk created machine), you can edit the home positions of each axis, this would be the easiest way.
Seth Madore
ysymidi
in reply to: seth.madore
In that case(Create a home position), I would have to assign Z, X, Y right?
But I don't want to move X. I just want to lift up Z, and move back(to Y380) so that I can easily change stock.
My previous PP worked this way, before I update the PP....
