Fusion Manufacture
Mach4 Post Processor for plasma
39 REPLIES 39
Message 1 of 40
chuck767
1114 Views, 39 Replies
Anyone know of a 360 post-processor for Mach4 Plasma?
39 REPLIES 39
Message 2 of 40
serge.quiblier
in reply to: chuck767
Hello @chuck767
Have you tried the Mach3 plasma post?
Is it incompatible?
https://cam.autodesk.com/posts/download.php?name=mach3%20plasma&type=post
Regards
______________________________________________________________
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
Serge.Q
Technical Consultant
cam.autodesk.com
Message 3 of 40
chuck767
I have not tried it, but I would be very surprised if it would work, considering that Mach4 is a complete rewrite of Mach3
Message 4 of 40
seth.madore
Right, but the rewrite had more to do with how Artsoft was able to run on modern hardware (computers) and less to do with the g-code that it could digest, right?
Seth Madore
Message 5 of 40
chuck767
in reply to: seth.madore
Seth,
good point, I will take a look at it.
I do know, and you are also aware, the M commands for  laser control, changed from M10/M 11 to M63/M62.
Message 6 of 40
serge.quiblier
Hi @chuck767
then this means that a little change to the onPower function can resolve the issue :
function onPower(power) {
  initialG31 = false;
  writeBlock(mFormat.format(power ? 3 : 5));  // M command can be changed here
  powerIsOn = power;
  if (power) {
    onDwell(getProperty("pierceDelay"));
    if (zFormat.isSignificant(getProperty("pierceHeight"))) {
      feedOutput.reset();
      var f = (hasParameter("operation:tool_feedEntry") ? getParameter("operation:tool_feedEntry") : toPreciseUnit(1000, MM));
      zFormat.setOffset(0);
      zOutput = createVariable({prefix:"Z"}, zFormat);
      writeBlock(gMotionModal.format(1), zOutput.format(getCurrentPosition().z), feedOutput.format(f));
  } else {
      zFormat.setOffset(getProperty("pierceHeight"));
    writeln("");
Regards.
Serge.Q
cam.autodesk.com
Message 7 of 40
chuck767
in reply to: serge.quiblier
thanks for the input, hopefully somebody(Seth 😊) can put that into a post processor for Mach4
Message 8 of 40
seth.madore
@chuck767 nope, I am not nearly qualified to add posts to the Fusion library.
Or, are you asking for some assistance in modifying your post to work? That, I can do!
Seth Madore
Message 9 of 40
chuck767
Seth,
My bad, I thought you actually built the laser post processor for fusion 360.
I see now that you did a modification to an existing one.
Hopefully somebody can generate a plasma post processor for Mach4.
thanks,
Chuck
Message 10 of 40
engineguy
@chuck767
See image below, simple example shape, first image is the shape in Fusion and the second is in Mach4 which seems to accept the code and run the shape, obviously I have not done any settings for the actual machine but the code does run, I did set it to "Use Z" option so that it shows the movement more clearly.
The only mod done to the PP is the one shown by @serge.quiblier, try just changing the 3 and 5 to 62 and 63 to get the code shown below, let us know if it is close to what you need 🙂
Fusion ScreenFusion Screen
Mach4 Plasma ScreenMach4 Plasma Screen
N10 G90
N15 G71
(2D Profile1)
N20 G0 Z15.
N25 G0 X41.784 Y17.597
N30 G0 Z0.
N35 M62
N40 G4 P1.
N45 G1 X44.58 Y21.743 F1000.
N50 G2 X44.713 Y22.247 I0.36 J0.175
N55 G3 X47.05 Y44.265 I-8.296 J12.014
N60 G3 X24.931 Y43.274 I-10.634 J-10.004
N65 G2 X24.419 Y43.173 I-0.315 J0.247
N70 G3 X-24.419 I-24.419 J-43.173
N75 G2 X-24.931 Y43.274 I-0.197 J0.348
N80 G3 X-47.05 Y44.265 I-11.486 J-9.013
N85 G3 X-44.713 Y22.247 I10.634 J-10.004
N90 G2 X-44.58 Y21.743 I-0.227 J-0.329
N95 G3 X44.58 Y-21.743 I44.58 J-21.743
N100 G3 Y21.743 I-44.58 J21.743
N105 G1 X39.593 Y22.091
N110 M63
N115 G0 Z15.
N120 M30
Hope this helps 🙂
Message 11 of 40
chuck767
in reply to: engineguy
Yes, this solution works fine.
I was hoping somebody could actually put it into a post processor so that people would not have to manually change the M5/3—to M62/63.
thank you,
Chuck
Message 12 of 40
engineguy
@chuck767
Not hard to do, you can do it yourself, worth the practice just to gain a little knowledge 🙂
I have attached it to this post for you, just import it to your Local Personal Library or your Cloud Library, that way it shouldn`t get overwritten by any updates, also turn off the Automatic updates in your Preferences just to help that 🙂
The PP is named as a Mach3 PP but you can change the name to anything you want 🙂
Message 13 of 40
chuck767
Thanks, that’s a good idea I need to practice.
Chuck.
Message 14 of 40
chuck767
Finally got around to modifying the MACH3 plasma post processor per your suggestion.
When I open the Mach3  file I see no reference to “M3, M5 .
So I’m wondering what I modify to make the changes you recommend?
Chuck
Message 15 of 40
engineguy
@chuck767
The PP that I uploaded is set to output M62 and M63, if you want/need it to be M3 and M5 then see the image below, all you need to do is change the 62 and 63 to 3 and 5 on the highlighted line 440, hope that helps 🙂
Message 16 of 40
chuck767
Thanks, I was searching for M62 M63 and could not find anything.
Now, I understand that I’m simply looking for 62 or 63 or with Mach3, 3 or 5.
when using the M62 or M63, they need to include P#.   # is output port. Ie M62P2.
thanks for your help,
Chuck
Message 17 of 40
chuck767
correction ------"when using the M62 or M63, they need to include P#. # is output port. Ie M62P2."
should read,
when using the M62 or M63, they need to include P#. # is output NUMBER. Ie M62P2.
Message 18 of 40
chuck767
Seth,
Ok, you offered to help "are you asking for some assistance in modifying your post to work? That, I can do!"
Attached is the PP for Mach3 Plasma done By Artsoft.
Here is what needs to be done To the Post processed Mach3 Plasma code to make it work on Mach4,
if you are still willing to help. - 🙂
1,   Above any G0 Z0insert"M62P2"
2,   Delete all "M3"
3,   Replace all "M5" with "M63P2"
4,  On the next to the last line of the Mach3  Gcode replace, "G0 Z0.6" with "G0 Z0.6 X0 Y0"
Let me know what you think?
Chuck
Message 19 of 40
seth.madore
@chuck767 couple of points of note:
1) There are no G0 Z0's output with the post you shared, or any Z move for that matter
2) Nor is there a "G0 Z0.6" at the end, it simply ends in:
N23900 M5
N23905 M30
Seth Madore
Message 20 of 40
chuck767
Seth,
I apologize, apparently I was looking at the wrong G code output for my last posting.  Not sure what went wrong.
I’ve been trying different things and need to go back and look at the configuration that I know works and get back to you.
thanks,
Chuck
