I have two 3/4 axis vertical mills of which both run a 4th axis rotary table. This rotary axis turns about the X-axis so called A-axis. I've downloade a post processor from Autodesk forums which I'll attache to this post. I'll also attached the part I'm looking at milling when I figure a way to get this to work. The tool path seems to generate with no issues and same with the code. However, when I generate the code to run in Mach3 the piece just keep on turning in the rotary axis and do not actually cut out the pockets as designed. I'm looke at the processor and with my limited knowledge can't seem to fin an issue(that's maybe due to my limited knowledge). What I do notice is that there is no Y-axis movement during the process on Mach3(Y= 0)?
The part's code is 1001.tap
