<Making changes to a 2D Adaptive toolpath generated 'Internal CAM kernel' error
tgford58
tgford58
I am reporting this issue as requested.  Is there anything else you need?
seth.madore
Could we get our hands on the file that is generating this issue?
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply
Seth Madore
tgford58
I've attached the entire file.  When the error was generated I was building the CAM programming.  This occurred on the first 2d Adaptive after the drill cycles.  I was manipulating the minimum cutting diameter in the Passes Tab.  If I remember correctly it errors at about .08 for the diameter.
It said to report the issue, I wasn't sure were to do that.
Thank you
