How can i check what is bottle-necking the cam from utilizing the system resources better? If i run a complicated adaptive tool path, my overall cpu utilization is around 20%, which leaves a lot on the table and in essence means that i'm waiting 5 times as long as i should for the task to finish ?
When i generate the paths, fusion first spawns 3 cam kernel tasks that momentarily utilize bit more resources and then is left with only 1 that doodles around 20-30% utilization, peaking in the 43% range for the rest of the generation.
It doesn't seem that i'm memory or IO bound here, so the only thing seems to be the CAM performance, which i would assume even without parallelism would consume 100% of a single threads performance.
