Fusion Manufacture
Loops in contour path
6 REPLIES 6
dmealer
144 Views, 6 Replies
Hello all!!
Please take a look at the attached screenshot. The tool should be contouring the outside of the part.This is a proven program that has run before. All i did was adjust the stock. Nothing was done to the tool paths. I even adjusted the stock back to what it was and even tried opening a older version file that was made before the last update and no luck. Fusion wont even re pick the contour correctly. Any help is greatly appreciated.
6 REPLIES 6
dmealer
in reply to: dmealer
Update. I found a previous version that opens correctly. as soon as you regenerate the path the errors appear.
seth.madore
Would you be able to share your Fusion file here?
File > Export > Save to local folder, return to thread and attach the .f3d/.f3z file in your reply.
Seth Madore
dmealer
in reply to: seth.madore
There ya go buddy
seth.madore
Man, that looks terrible...
I don't have a solution for you at the moment (other than to use a 3D toolpath), but I've opened up CAM-49552 to investigate this issue.
Seth Madore
dmealer
Thank you sir!
leo.castellon
If you go back to design and use "project a sketch", it seems to result in a much cleaner contour. See attached.
LeoC
