Looking for a post for Daewoo Puma 230
aeschlimandC569K
aeschlimandC569K
Recently picked up a Daewoo Puma 230msc lathe with live tooling, sub spindle, and a Fanuc series 18 control. When I tried to program my first part I got some errors. Can anyone shed some light on the matter?
DanielMolloy
Hi @aeschlimandC569K,
There is a generic doosan mill/turn post which might well work for you, i will include a link below. This should get you somewhere close although i'm not sure about whether it will support the sub.
https://cam.autodesk.com/posts/download.php?name=doosan%20mill-turn%20fanuc&type=post
If this doesn't give you what you want we have developed a doosan mill/turn post which fully supports the sub, again, i will incldue a link below.
Doosan Lynx Mill Turn | Buy Licenses | Find Out More (massif.dev)
aeschlimandC569K
thank you, i will give that a try!
vpace91423
We have one for a 2000y that works great for us. I will dig it up
vpace91423
This is for a Doosan 2000Y with Sub Spindle and Live Tooling circa 2006, Fanuc 18i control.
You should test it out for your machine but it works for us with little manual adjustment. As always, verify slowly what works for you and what doesn't. There are check boxes for parts catcher, ejection, cut off with drawbar, cut off and feed with sub spindle etc.  Good luck
aeschlimandC569K
thank you, I'll give that a try as well. I'm liking the sound of that, being that it is for a series 18 control and sub spindle
