Fusion Manufacture
link feedrate
9 REPLIES 9
Message 1 of 10
DarthBane55
458 Views, 9 Replies
link feedrate
Would it be possible for Autodesk to unlock the "link feedrate" that is in "compare and edit" but greyed out?
At the moment, when you choose to keep the tool down, it goes from one cut to the next using the cutting feedrate.  For some materials this becomes pretty slow, but rapiding up  and down wastes time.  In general, keeping the tool down, but with a higher feedrate would be a big benefit for cycle time.  There is some way around it by using "always use high feed" or similar, but it forces you to say that the top height is equal to the bottom height and set the retract plane to be same as top height, and set the "safe distance" to zero.
Keep tool down and using "link feedrate" would simplify the process.  It is already there, just not available to use.1.png
9 REPLIES 9
Message 2 of 10
seth.madore
in reply to: DarthBane55
This has been requested more than once, I know of one ticket  (CAM-9094) that was opened for it. That would be a nice QoL improvement, imo. I'll mention this to the devs and see if there was anything we could implement.
Seth Madore
Message 3 of 10
DarthBane55
in reply to: seth.madore
Awesome thank you!  I searched for it, but didn't get any result 😞
Message 4 of 10
DarthBane55
@seth.madore Hi Seth, this issue is not solved yet.  You gave us a ticket number but...  where do I go to see the ticket number status?  I have no clue where these are listed...
Thanks!
Message 5 of 10
seth.madore
That's actually not anything that the public has access to, it's for internal use only. Sharing the ticket number here gives us something to refer back to if/when a bug or improvement is made, and it also presents something tangible to the customer
Seth Madore
Message 6 of 10
DarthBane55
ah ok, I see... well it's not very tangible to me at the moment 🤣
Could you check it out and see if it's in the works please? 🤓
Message 7 of 10
seth.madore
It's still open and unresolved, sorry. I too would like to see this decoupled, fwiw
Seth Madore
Message 8 of 10
DarthBane55
Alright, well thanks for checking!
Have a great weekend!
Message 9 of 10
still 2 years later???
Message 10 of 10
Yep! We've talked about link feedrates a bit, but, in general, it's fallen lower on the priority list.
Seth Madore
