Fusion Manufacture
Leaving an Onion Skin for woodworking
3 REPLIES 3
adminVB2VY
106 Views, 3 Replies
Hello, I was wondering if anyone knows how to do a onion skinning in fusion. I have some parts to cut out of wood and want to leave a onion skin
3 REPLIES 3
seth.madore
in reply to: adminVB2VY
Just adjust your Bottom Height of a toolpath so it stops just short of the bottom surface. You can even add tabs to that, so it leaves a thin skin of material where tabs are and cuts thru the rest of the area.
Seth Madore
Are you cutting it after, or leaving it entirely? Just do an axial stock to leave of your desired thickness, bottom set to Model Bottom
Please click "Accept Solution" if what I wrote solved your issue!
adminVB2VY
in reply to: seth.madore
Thank you for the suggestion. We are trying right now to see if it works
