Leaving a Large wood Slab - with 55mm Spoil board cutter
andyC73F4
andyC73F4
Hi All,  I am very new to Fusion 360 ,  I am trying to create a programme to level off twisted large wood slabs,  I have been trying to create a facing Operation to runs over the total dimensions of my slabs,  but what I really need is a program, which removes 1mm to 2mm per pass,  if there a simple way to program this ?  I can find the setting in the facing operation to lower per pass  ?
Andy
g-andresen
Show pictures of your project
I can also imagine that the topic would be better placed in the Manufacture Forum.
günther
andyC73F4
Ok thanks you, this is my 1st post here , I will re post at Manufacture Forum. ..
Here is a screen shot I am simply trying to remove 1/2mm per pass across the total width and length of a wood slab.
This is my doing it manually with a router sled .- https://youtu.be/WvK1UC-qXPg?t=336
