Fusion Manufacture
Lead in position too close to part
3 REPLIES 3
pg471939HMBM
119 Views, 3 Replies
Hello, in this part I want to use a 50mm face mill to roughing this piece and leave some stock to finish with a 10mm flat mill. The problem is that when I do a 2D pocket with the 50mm cutter, the starting point is to close to the piece. I already try using lead in and changing parameters but it always touches the part when going down. Is there a way to change the starting linear distance? I atached a photo showing the problem. Thanks for the help, I am starting to learn how to use CAM.
Tags (2)
3 REPLIES 3
jscott6SWZG
in reply to: pg471939HMBM
Try changing the lead in to perpendicular
AdamKunzo
extend the lead in in linking tab
seth.madore
If you are still having issue, would you be able to share your Fusion file here?
File > Export > Save to local folder, return to thread and attach the .f3d/.f3z file in your reply.
Seth Madore
