Fusion Manufacture
Lathe program outputs feed per rev for turning tools but not for drills
2 REPLIES 2
gabriel.dsilva
197 Views, 2 Replies
I specified feed per revolution for an OD turning toolpath and a drill toolpath. On posting, fusion leaves the turning toolpath in feed per revolution, but converts the drill path to feed per minute and provides the warning “Post does not support feed per revolution mode. Feeds were converted to units per minute.” The post is for a Haas SL30.
I want to use feed per rev for all lathe toolpaths. What settings do I need to change to have Fusion output drill toolpaths with feed per revolution?
Tags (4)
2 REPLIES 2
Are you capabale of making small edits to your post?
Yes, I should be.
