Announcements
Lathe profiling cutter comp problems
steveHDPJT
steveHDPJT
For whatever reason Fusion is generating these fairly silly tool paths when I select cutter comp to be "in control". For example, using Turning Profile to turn down a diameter to 31.8mm with cutter comp set to "in control" comes up with this:
Part OD is 31.80mm. Inner radius in the profiling op is set to 15.90mm (exactly half). Yet it comes up with these weird divots and redundant loops in the toolpath, and then spits out code at 30.2mm - it shouldn't be doing this, the whole purpose of using G41/42 is that you use the exact part geometry for imaginary tool point and correct the toolpath using tool radius compensation, right? The tool radius in Fusion is set to 0.80mm... but since I'm not asking it to compensate within Fusion that should be irrelevant, and the code should spit out at 31.8 regardless? Am I missing something or is this actually a fundamental flaw?
HughesTooling
It looks like you need to set the tool up to use tip centre in the tool library if you want to use In Control compensation.
Mark
Mark Hughes
Owner, Hughes Tooling
steveHDPJT
Thanks, that seems to have done the trick. I don't understand why that is though - if compensation is set to "in control" then irrespective of all else, the toolpath's generated X/Y/Z values should follow the actual part geometry exactly (plus any stock to leave that may be specified), no?
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
