Fusion Manufacture
Lathe: Grooving roughing on center?
7 REPLIES 7
Message 1 of 8
programming2C78B
234 Views, 7 Replies
see pics. Using a 2mm (.078) groover in .120 wide notches. I'd prefer if it grooved on center (or atleast somewhere down near the ID), but with a .078 Max Grooving Stepover it really keeps off the shoulder and doesn't even go into the groove, just the OD. Yes, my inner Radius is set to the smallest diameter face.
With .04 stepover, it acts how I want but now I have almost 2x as many roughing plunges as actually necessary.
Is there a better way to go about this that I dont see right now?
Please click "Accept Solution" if what I wrote solved your issue!
7 REPLIES 7
Message 2 of 8
Grooving is one of the Turning toolpaths we're actively working on, so your struggles are not foreign to us and the work we're doing.
Would you be able to share your Fusion file here or privately?
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply. To share the file privately, it's the same process, but email it to me: seth DOT madore AT autodesk DOT com
Seth Madore
Message 3 of 8
emailed
Message 4 of 8
Yeah but you didn't send it to the email I described above 😛
(no worries, I found it)
Seth Madore
Message 5 of 8
With the tools we have out our disposal currently (Production version of Fusion), the best I can suggest is to use a "Single Groove" toolpath and some sketches to drive it:
This will rough out the two grooves right on center and then you can go back with a full width Groove toolpath and finish it up. (turn on Rest Machining "from previous ops" to reduce the toolpath machine time a bit)
Seth Madore
Message 6 of 8
Thats what I did for now, just used each shoulder as the sketch with .01 axial stock to leave and ReST on the groove ops. Hopefully it gets sorted out quick! (Just like round boring bars 😉 )
Message 7 of 8
It's likely the case where Grooving is going to be solved before custom boring bars (Micro-100 style). As for "round" bars, that's what we have now. There isn't a toggle in the Library, but the graphical representation of the tool is round:
Seth Madore
Message 8 of 8
This is about as close as I could get, it has a 2* and 6* relief angle but I got it with 5*. We'll see this week if it cuts right.
