Lathe drilling Fanuc 3T
kretallick144
kretallick144
Hi again,
Wanting to drill a simple countersunk hole in the end of a shaft.
Code i get from the Fanuc post processor is,
(DRILL3)
N2680 M1
N2690 T0303
N2110 G98
N2710 M8
N2720 G98
N2730 G97 S1500 M3
N2740 G0 X.00 Z60.
N2750 G0 Z50.
N2760 G81 X.00 Z-3.5 R9. F333.333
N2770 G80
N2780 Z60.
N2790 M9
N2800 G28 U0.
Lathe doesnt like line N2760.
Any ideas?
kretallick144
Problem solved!  G81 removed and all is well.
Marco.Takx
Hi @kretallick144,
If you have to modify your NC file every time you can modify your post processor yourself.
You need some JavaScript knowledge.
You also can contact your Local Reseller in the link below how can help you.
HSM post adjustments needed? Find your right contact here.
If my post answers your question Please use  Mark Solutions!.Accept as Solution & Give Kudos!Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
kretallick144
Hi Marco,
Yes i have a bit of modifying to do.  Im learning as i go.
I have zero javascript knowledge and unfortunately not in the position to pay a professional at the moment.
I have started with the most involved part, so once i master it, other parts will be easy.
