Fusion Manufacture
lathe c-axis engraved text mirrored on parts
4 REPLIES 4
jpopov17
535 Views, 4 Replies
I also posted in the post specific forum but figured I would try answer day here.
I am modifying a post for a c axis live tooled lathe.  I have got basics down from looking at other posts but am having a hard time figuring out how to fix this.
Say I want the engrave "TEST" on the face of a part. When machined it comes out as a mirror image of the word.  I believe this is because my c-axis values are positive when they should be negative and negative when they should be positive.  Basically I need to multiply my C numbers by -1
How can I do this with Javascript?
My part looks fine in on the computer so it is happening when I post it.
Attached is my post.
Thanks for any help!
4 REPLIES 4
ArjanDijk
in reply to: jpopov17
have you tried:
var cFormat = createFormat({decimals:3, forceDecimal:true, scale:(-1*DEG), cyclicLimit:Math.PI*2});
Have not tested it myself, but seems the easiest way to change the rotation direction. In this case rotation must also be wrong during indexing, so can you check that?
Inventor HSM and Fusion 360 CAM trainer and postprocessor builder in the Netherlands and Belgium.
jpopov17
in reply to: ArjanDijk
Thanks you were on the right track and got me looking in the right place.  I tried that and no change.  Then I realized that because I am using polar coordinate interpolation I actually need to change my y axis instead of the c.
This solved my problem:
var yFormat = createFormat({decimals:(unit == MM ? 3 : 4), forceDecimal:true, scale:-1});
before it was:
var yFormat = createFormat({decimals:(unit == MM ? 3 : 4), forceDecimal:true, scale:1});
HughesTooling
before it was:
Does that end up mirroring your Y axis for everything? Or where you only having trouble when you use the 4th axis. I'm pretty sure what you've done will mirror all toolpaths so your G02\G03 moves will now be wrong.
Mark
Mark Hughes
Owner, Hughes Tooling
tisler
in reply to: HughesTooling
@HughesTooling  You are right. It messes up G02 in G03 moves.
I am having the same problem, do you have a solution?
