Fusion Manufacture
Lathe - boring bar goes through stock
3 REPLIES 3
wm_crash
130 Views, 3 Replies
Hello Fusion experts and people who have already made the mistakes I am making,
I have a small part I am working on, and using a boring bar for the first time. This is a two sided lathe operation, so there is stock to remove on both sides. The boring bar tries to go through the Z axis, ends up on the other side and does some work.
My question is, am I doing something wrong, or do I always have to specify the back limit face for a boring operation? Or should the toolpath be properly generated either way, but I am doing something else wrong?
File included, thanks in advance!
Cosmin
3 REPLIES 3
seth.madore
in reply to: wm_crash
It does appear that Fusion isn't recognizing that the shallow pocket doesn't go all the way thru. I'll investigate this and open a task if needed (I suspect it will be needed).
To easily solve your issue, just set the "Back" setting to "Selection" and select the back face:
Seth Madore
seth.madore
I've opened up CAM-44144 to investigate this issue
Seth Madore
wm_crash
in reply to: seth.madore
Yeah, that's what I did and that solves the issue. I am in learning mode and just wanted to make sure it's just a small bug as opposed to me doing things the wrong way.
thanks,
Cosmin
