Announcements
Lathe 4th axis post process error
Hello guys,
Im new to Fusion, and I just tried my first lathe model and the toolpath worked just fine but when I go to post process I'm getting the message below, Im using HAAS - A-axis (pre-NGC) config, my machine run on USB CNC controller, can you please advise
Charbel
Information: Configuration: HAAS - A-axis (pre-NGC)
Information: Vendor: Haas Automation
Information: Posting intermediate data to 'C:\Users\csaad\Desktop\1001.nc'
Error: Failed to post process. See below for details.
Code page changed to '1252 (ANSI - Latin I)'
Start time: Wednesday, March 25, 2020 5:20:22 PM
Code page changed to '20127 (US-ASCII)'
Post processor engine: 4.5633.2
Configuration path: C:\Users\csaad\AppData\Local\Autodesk\webdeploy\production\edf0a409d74cbc712b7f97f98853d005413e965e\Applications\CAM360\Data\Posts\haas with a-axis.cps
Include paths: C:\Users\csaad\AppData\Local\Autodesk\webdeploy\production\edf0a409d74cbc712b7f97f98853d005413e965e\Applications\CAM360\Data\Posts
Configuration modification date: Friday, March 6, 2020 5:09:36 AM
Output path: C:\Users\csaad\Desktop\1001.nc
Checksum of intermediate NC data: 2357ceac3055f2e5fcebd02a5c999e1a
Checksum of configuration: 37e3fb5637249079d4a53fa1c92dab5c
Vendor url: https://www.haascnc.com
Legal: Copyright (C) 2012-2019 by Autodesk, Inc.
Generated by: Fusion 360 CAM 2.0.7824
Error: Error: Direction is not supported for machine configuration.
Error at line: 1
Stack dump:
("Direction is not supported for machine configuration.")@:0
onOpen()@C:\Users\csaad\AppData\Local\Autodesk\webdeploy\production\edf0a409d74cbc712b7f97f98853d005413e965e\Applications\CAM360\Data\Posts\haas with a-axis.cps:395
Failed while processing onOpen().
Error: Failed to invoke function 'onOpen'.
Error: Failed to invoke 'onOpen' in the post configuration.
Error: Failed to execute configuration.
Stop time: Wednesday, March 25, 2020 5:20:22 PM
Post processing failed.
Arun.rs
Hi @Anonymous
Thanks for raising your concern via Forum.
Could you please share your model file? I will take a look at it.
File>Export>.F3d save the file and reattach the file to this thread.   Make sure zip the file before attaching.
Regards
Arun.RS
Technical Consultant - Post Processor
boopathi.sivakumar
@Anonymous
From the image what i can see is the orientation is set wrong in the setup the the rotary axis is set about Y in the model it should be around X something like this
if it again throws the error kindly share the .F3d file
File>Export>.F3d
Boopathi Sivakumar
Senior Technology Consultant
Thank you so much for your help... The problem was i need to make it arround the X axis not the Y axis
Best regards,
Charbel
Thank you so much man, the problem was the orientation of the x axis and not the y axis
Arun.rs
Hi @Anonymous
Glad to hear the issue has been resolved!
Arun.RS
