Fusion Manufacture
Last setup breaks IPS on all previous setups, deleting or suppressing last op and previous setups are ok and IPS is generated.
10 REPLIES 10
Message 1 of 11
dgoller2RNYJ
304 Views, 10 Replies
I don't know what about the last setup not only breaks that last op, but also prevents all previous ops from successfully generating mesh for in process stock.
I don't see how last operation breaking all previous is even user error as i'd expect not break working setups when i add setups at the end.
What about the attached file breaks everything else once last op is unsuppressed?
Noticed i can toggle the mesh generation issues when i was going to create a copy of the file with the second part's setups deleted and all previous ones again generated in-process stock.
Models are from inventor, not native fusion 360 models, as you will see i started out wrong and had to do a bit of extra work updating to the latest customer request, always inserting the inventor models into a new design seems to work better, not done here, while my oops of starting to manufacture after uploading is messy now, it doesn't seem to explain how the fifth op can break the previous four, that were already simulated and posted.
Let me know if you need a copy with the links broken, haven't really dealt with .f3z much, so I hope this works as is.
Thanks in advance for looking.
Daniel
10 REPLIES 10
Message 2 of 11
seth.madore
in reply to: dgoller2RNYJ
Are you working in Production version of Fusion, or are you using the Insider build?
Seth Madore
Message 3 of 11
dgoller2RNYJ
in reply to: seth.madore
It should be production version, just downloaded, installed and using, unless using select preview options invalidates that statement.
I googled: https://feedback.autodesk.com/key/Fusion360Insider i am not partaking in.
Message 4 of 11
seth.madore
Can you expand a bit on your issue? I've unsuppressed the last Setup (and the toolpaths) and I can get IPS to calculate for everything but the last toolpath. This does require some investigation.
However, the IPS is still valid for all prior toolpaths and prior Setups. Are you seeing something different?
Seth Madore
Message 5 of 11
dgoller2RNYJ
Breaks all the way from the top down.
Rest is still calculating other ops, so i only have the very first op to screenshot.
In short, everything breaks.
Message 6 of 11
seth.madore
Are you on PC or Mac? What version of OS are you running? Are all drivers up to date?
I'm assuming that Fusion is also up to date?
Seth Madore
Message 7 of 11
dgoller2RNYJ
This is Windows 11
I'm not keeping Fusion from updating itself.
Odd how it reports it as Windows 10?
I'll see if Nvidia does have a newer driver.
Latest installed, no change to how Fusion acts
SCHLECHT is the original bad OP20, i made a new OP20 setup, all ops copied over fine. Screenshot is just after unsuppressing the bad OP20.
While this isn't a solution, i can continue working on this file.
Message 8 of 11
dgoller2RNYJ
I would like to know what broke, if I broke it, if the software glitched and/or how to prevent another such occurrence.
Message 9 of 11
dgoller2RNYJ
Looks like I got an automated email Saturday asking if I got the answer I needed and this is actually still unanswered.
A work around isn't addressing the initial breakage.
Anything I can do to make this maybe easier to reproduce, so it can get fixed?
Best Regards,
Daniel
Message 10 of 11
seth.madore
I've been poking at your file and I've not been able to reproduce this issue on my end, unfortunately 😞
Could you capture this behavior in a screen recording? I can at least get the issue logged with your data set as well as your recording.
Seth Madore
Message 11 of 11
dgoller2RNYJ
I'll likely have to get the screen recording done next week, it's a wild week and i want to  make sure it's the shortest possible video showing the problem, so i might need to minimize/reduce the setups in the problem file too.
