Keyway milling with Live tooling
jeph00
jeph00
New F360 user.
I attached the part I am trying to make. What is the best way to mill the keyway with a 0.25 flat endmill? Can't seem to make 2d adaptive clearing or 2d contour work. Can anyone help me? I want to do this with live tooling.
NickErmis
I would just use 2d contour.  You can play with lead in or lead out so you dont plunge in the part.  Also, you could just draw a construction line and do a 2d trace.
jeph00
So bear with me. I cant seem to select a line or face in the key way that'll get me a tool path.  I see you got the results I want but how did you do it?
NickErmis
You will want to use the Alt key when selecting just one feature, otherwise it will try and do the full contour.
NickErmis
Let me know if the screencast works...
jeph00
I do not see a screencast but I know what you mean. Thanks for the prompt responses!
