Fusion Manufacture
Keep Tool Orientation for following Operations
6 REPLIES 6
Simon_Fr
334 Views, 6 Replies
A way to keep the Tool Orientation for following Operations (in Fusion360 Manufacturing). Imagine having a Template for Drilling, Countersinking and Reaming a Hole. You load it in, and it Automatically chooses the Holes because you set the Diameter Range. But the Holes are on the left side of the Part. Now you have to go in every single Operation and choose the Tool Orientation. Now imagine having different Sized Reamed Holes, Threads and so on.  The same goes for Roughing and Finishing Operations, that's why the Hole Expert isn't an Option. Can there be a function that will set the Orientation for following Operations? Or is there a way to implement a function in which you can choose various Orientations beforehand and then just select "Orientation 1" for example in the Tool Orientation Section?
6 REPLIES 6
seth.madore
in reply to: Simon_Fr
And that's why we're working on multi-axis drilling 🙂
Seth Madore
Simon_Fr
in reply to: seth.madore
That's nice to hear 😄
Will there be any function for Milling?
seth.madore
I believe that there is consideration for the Hole Recognition workflow, but I'm not intimately involved with the project. I can check in with the developers to see if this is involved in the planned work.
Seth Madore
Simon_Fr
I would appreciate it if you could do that.
Anyway, thanks for the already fast and informing replies.
programming2C78B
I've asked for this as well. Something like a toggle box of "use prior tool(path)s orientation"
Please click "Accept Solution" if what I wrote solved your issue!
seth.madore
I did check in with the developers regarding non-drilling templates and Hole Recognition. This is on the long term roadmap for our Multi-Axis improvements, but we're going to make sure we address the fundamentals before we move into this area.
@programming2C78B there is some work that is actively being done to make the whole concept of Tool Orientation (and reuse) a LOT smoother for the user. Stay tuned... 😉
Seth Madore
