Fusion Manufacture
ITNC 532 POST PROBLEM ON 45 DEGREES HEAD POST ON 3+2 AXIS MACINE
1 REPLY 1
dan_duta
65 Views, 1 Reply
Hello
We have a Lagun CM6 machine with 45 degrees head ( 3+ 2 axis ). We try to post with cycl 19, and is not working.
In our machine for head rotation and tilt planes we have CYCL 319 and parameters Q1570=0. Q1571=0. Q1572=0. Q1589=+1.
When we post with other software it returns this code:
CYCL DEF 319 SPATIAL
Q1570=0.
Q1571=0.
Q1572=0.
Q1589=+1
and it works.
Do you have a solution for me?
Dan D.
1 REPLY 1
a.laasW8M6T
in reply to: dan_duta
Cycle 319 is an OEM cycle made by Lagun specific to that machine(or series of machines)
All 3XX cycle in Heidenhain are OEM cycles not standard Heidenhain so they wouldnt be present in the Fusion Heidenhain post.
Without more information about how the cycle works we cannot help more
We would need ideally the pages from the Lagun manual describing the cycle and what all the Q values are for
A good option here would to be to get a postprocessor customised through a partner, you can find them here:
https://customersuccess.autodesk.com/partners/search?search=&solutions%5B%5D=Fusion%20360&services%5...
