Fusion Manufacture
Is there a way to add multiple depth to a 4th axis parallel rotary milling strategy?
2 REPLIES 2
kksAZZV7
74 Views, 2 Replies
Hello
The tool is entering the material (is "plunging into" the correct word?) to deep, when I use a 4th axis parallel rotary milling strategy. Is there a way to avoid that, similar to multiple depth feature?
I have attached the milling program I am working on.
I look forward to hear from you.
Br. Kristoffer
2 REPLIES 2
just rotary pocket to rough or flip the front back around to gradually enter the un machined material.
seth.madore
in reply to: kksAZZV7
Have you tried the Rotary Pocket toolpath, as it's intended for Roughing?
Seth Madore
