Fusion Manufacture
is it possiable to in fusion to give 2 off set to the same tool
2 REPLIES 2
samQBELZ
130 Views, 2 Replies
hi all
just wonder on my cv5 500 Mazak 5-axis mill we have an option in the tool list data to make multi-tool (for example 2x tool 15/15a but give them 2 different offsets for finishing 2 different areas on the part
I know I can in my model make a second tool path and add or take stock offset to count change or finish needed then post it to work for the tool
but just wondering if possible to give a tool letter in fusion the matches then Mazak 15 and 15a
or some sort work around like this with fusion that then work with Mazak controller tool data
sam
2 REPLIES 2
seth.madore
in reply to: samQBELZ
No, you will need to duplicate the tool and assign a different offset number to it.
Seth Madore
samQBELZ
in reply to: seth.madore
thanks
