Fusion Manufacture
Invalid Post Processor Error
5 REPLIES 5
baz1l
255 Views, 5 Replies
I am trying to import the anilam conversational post processor and it says : Invalid Post Processor.
Link to the Post: https://cam.autodesk.com/posts/download.php?name=anilam%20iso&type=post
When I try to use the standard installed one I get the error:
Error: Failed to evaluate post configuration.
Code page changed to '1252  (ANSI - Latin I)'
Start time: Thursday, May 25, 2023 3:15:23 PM
Code page changed to '20127 (US-ASCII)'
Error: ReferenceError: ABC is not defined
Error at line: 198
Stack dump:
@C:/Users/admin/AppData/Local/Autodesk/Autodesk Fusion 360/CAM/cache/posts/anilam iso.cps:197
Any Advice would be greatly appreciated.
Failed while processing global script.
z
5 REPLIES 5
boopathi.sivakumar
in reply to: baz1l
Hi @baz1l
What version of the fusion you are running
Also could you attach the f3d file which is causing the this issue
File>Export>.F3d
save the file and reattach the file to this thread.
Boopathi Sivakumar
Senior Technology Consultant
baz1l
in reply to: boopathi.sivakumar
Version : 2.0.10811
baz1l
Here is the F3D file
baz1l
in reply to: baz1l
Sorry here it is
boopathi.sivakumar
in reply to: baz1l
It seems like you are still running on the old version of fusion some how, probably you may not opened fusion in a while. you might need to restart the fusion so it gets updated
Boopathi Sivakumar
