interpolating holes
interpolating holes
geremiah
interpolating holes
geremiah
hi
I have a hole dia 40 mm x 8mm deep through hole,
first I drill to diameter 39 mm but then the next milling operation, i want to be able to plunge 9 mm and then send cutter around hole in one cut, what is the correct milling operation to do this, at the moment im using the bore option.
I would recommend Circular or 2d Contour.
David
geremiah
thanks so much
2d circular worked great
