Internal CAM Kernal Error
jta49
jta49
I am receiving the "Internal CAM Kernal Error" again... I've followed what other older blog posts have done to fix it but have had no luck. Any Ideas?
seth.madore
The issue is stemming from your Heights tabs. However, I'm curious about your Setup. You've selected the base component, but then you are making a chain around the little posts that are not included in the Setup. What's your goal here?
Seth Madore
HughesTooling
I found I needed to select the whole component and I think you need to click the red arrow to switch the offset to the outside. There's still a warring about heights as @seth.madore  mentioned.
Mark Hughes
Owner, Hughes Tooling
jta49
Ahhhh... Ive been working to fast and botched my setup. Thankyou for the help, works now.
