Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
Internal CAM Kernal Error while using 3D Adaptive on Mac
1 REPLY 1
lukesmit695
112 Views, 1 Reply
I've looked through a lot of other threads and cannot seem to find the fix to this issue.
Any time I use 3D Adaptive, I get the error "Internal CAM Kernal Error", regardless of tool I use. I have tried using a sample tool from thee fusion library and get the same message.
I know that this issue has been a result of using Windows 7, but I am having this problem on either OS. My macbook running macOS Monterey and my work computer running Windows 10.
This is the error message with debug:
Feature flags: metrology-survey setup-sheet-viewer
Debug: Initialization elapsed time: 0 ms
Debug: Writing ironjob to /var/folders/49/pl72msy94vv08lvwx150l5mc0000gp/T/Neutron/Fusion360CAM/57006-1/operation5.ironjob
Debug: Writing jobfile to /var/folders/49/pl72msy94vv08lvwx150l5mc0000gp/T/Neutron/Fusion360CAM/57006-1/operation5.hsm-job
Debug: Using CAM kernel from: /Users/Luke/Library/Application Support/Autodesk/webdeploy/production/c0347846e8723221ace2044ddbdd09ef9609d855/Autodesk Fusion 360.app/Contents/Libraries/Applications/CAM360/camkernel
Error: Internal CAM kernel error. Please report through your support channel.
Debug: Autodesk dcamcomponents 1.136.2 pm12473
Autodesk CAM Kernel 3.72.4 (aa66f84f) STABLE aa66f84fee0e2286c966ba08d48d2455be552366 2022/06/02 13:00
Traceback (most recent call last):
File "operation5.ironjob", line 94, in <module>
job.run()
File "lib/hsmkernel/Operations.py", line 192, in run
File "operation5.ironjob", line 42, in onRun
op1.setParameter('tolerance', ) # calculationTolerance
TypeError: setParameter() missing 1 required positional argument: 'value'
Debug: Total processing time: 127 ms
Debug: Total elapsed time: 282 ms
Invalidated: Generation failed
I have no problem running 2D Adaptive, but I would like to use 3D so that it is model aware as I progress through smaller tools. I'll attach a file with a simple pocket.
Any help on this is much appreciated!
1 REPLY 1
Hi @lukesmit695
Thanks for posting.
I'm able to create a 3D adaptive toolpath for the below-attcahed model. Please have a look at the attached file.
Pramod
Technology Administrators
