Fusion Manufacture
internal cam error 3d adaptive
2 REPLIES 2
hackish
141 Views, 2 Replies
I was trying to coax 3d adaptive to cut the outside of my part and by adding a silhouette for the machining contour, I have received an internal cam error. The file is attached.
If I add an additional offset, it succeeds - I have a feeling the tool diameter won't fit and is confusing the strategy. HEre is the error traceback.
Debug: Autodesk dcamcomponents 1.168.0 pm12787
Autodesk CAM Kernel 3.116.2 (ef65b034) x64 STABLE vs2022 ef65b03494d9cb86e796a92afa5a65d00d1ae1b0 2023/02/02 04:00
Exception in thread THzlevels:
Traceback (most recent call last):
File "lib\threading.py", line 954, in _bootstrap_inner
File "lib\roughsteel\ZLevelsClass.py", line 1168, in run
File "lib\roughsteel\ZLevelsClass.py", line 1288, in Lrun
File "lib\roughsteel\ZLevelsClass.py", line 1058, in DoNextDowns
File "lib\roughsteel\ZLevelsClass.py", line 925, in NextZDown
File "lib\roughsteel\ZLevelsClass.py", line 820, in FindFlatLevel
File "lib\roughsteel\ZLevelsClass.py", line 777, in Overlap
File "lib\roughsteel\ZLevelsClass.py", line 773, in OverlapI
TypeError: '>' not supported between instances of 'NoneType' and 'float'
failedthreadinfo = ZlevelsCreator failed.
Debug: Total processing time: 125 ms
Debug: Total elapsed time: 1330 ms
Invalidated: Generation failed
2 REPLIES 2
seth.madore
in reply to: hackish
Just set your Boundary to "None", turn on Stock Contours, and then set Rest Machining to "From Prior Operations". Result:
Seth Madore
hackish
Thanks, this resolved the issue and allowed me to continue. Is the internal cam error a defect in the software that you create a PR on behind the scenes?
