Fusion Manufacture
In process stock not regenerating [no I'm not buying cloud credits to workaround this buggy program]
3 REPLIES 3
FrodoLoggins
195 Views, 3 Replies
In process stock for the below toolpath (and all subsequent toolpaths) does not regenerate (it used to).
Disabling/reenabling IPS, closing/relaunching Fusion does not get IPS to work.
The previous setup is protected and no I'm not buying cloud credits as a workaround so I can get IPS to work.
- Time Magazine’s Person of the Year 2006
- Apple M1 Max rMBP A2485 // Latest MacOS // Latest Fusion
- Usually working off files uploaded to Fusion as: Step, STL, SLDPRT. If it matters ask me.
3 REPLIES 3
rengfx
in reply to: FrodoLoggins
All I did was open your file and it's showing all the IPS for Setup C2 Flip and it appears to be working for all operations including all the C1 locked toolpaths
seth.madore
I was curious if it was working correctly for those WITH the Extensions, which @rengfx appears to have, so I took one for the team and had the Extensions turned off for my account (I can get them back). With no Extensions, nothing immediately generated, or so it appeared. So, I unprotected your last 2D Contour of C1 and everything in C2 started showing change of state
Seth Madore
FrodoLoggins
in reply to: seth.madore
6 days later and I'm having the same issue with IPS not generating. That's not bad, usually it's every day.
