if anyone has a post for this machine please send me the download
Solved by jameshorne0503. Go to Solution.
Hi Nick,
Can you confirm what controller this machine has?
After some research it seems that these machines come with the Arumatik-Mi control that doesn't have an official post. It does say that the control can run Fanuc programs with "little to no modification" so this would probably be your best place to start. You can find the Fanuc post here: https://cam.autodesk.com/posts/download.php?name=fanuc
If you run into issues and need help modifying this post to better suit you machine you can ask on this forum or if you fancy having a crack at modifying it yourself these resources will help you out:
https://cam.autodesk.com/posts/posts/guides/Post%20Processor%20Training%20Guide.pdf
https://www.youtube.com/watch?v=4OWT-O4oN8E
Hope this helps!
