Fusion Manufacture
Importing DXF showing irrelevant points not existing in the original file
4 REPLIES 4
eduardo.sanchez
118 Views, 4 Replies
Hi Fusion Manufacturing Community,
I do use DXF exported from Rhino 7 in a daily bases for 2d frame cutting.
Today I started to see random dots/points once the DXF is inserted on Fusion 360 file.
Any ideas on how to avoid this nuance?
Thanks a lot in advance for your help and kindness,
Eduardo
4 REPLIES 4
Would you be able to share your Fusion file here?
File > Export > Save to local folder, return to thread and attach the .f3d/.f3z file in your reply.
Also, could you share the .dxf file as well?
Seth Madore
These are the setting I've found work well for DXF exports. Try to avoid Simplify lines and arcs.
Mark Hughes
Owner, Hughes Tooling
Good afternoon Seth,
Thanks so much for your reply. Please find attached Fusion 360 File as well as original DXF created from Rhino 7.
Please feel free to get back to me should you have further questions,
Eduardo
Hi Mark,
Thanks for your reply and showing the DXF export Rhino Window. I will try your solution!
Truly appreciate your time and kindness with this,
Eduardo
