Fusion Manufacture
import SVG to fusion 360 from inkscape
4 REPLIES 4
carsten.johanssonCQAFK
1878 Views, 4 Replies
Hi
Not sure if this is the right place to ask but I give it a try.
I have a image that I have convert to SVG with Inkscape.
I have select ungroup and save it and then import it in Fusion 360.
That I want to do is not engraving the image because I do not want to make a "hole" where the text is and the image. I want to make the "hole" around the text and image.
The problem I have (I think that is the problem) is the SVG file have alot of  and alot of line even if that is just a straight line it have have at least two and when fusion trying to read them all it freeze for a while and somtime the program stop working. I have try with at least 8 times now but same problem. I have scale the SVG to think that is the problem but is not.
I have attached a image that show the SVG have alot of dot in Fusion 360 and maybe that is the problem?
4 REPLIES 4
Can you use the insert pic tool it is the camera icon above attaching images seems to be broken.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
That is normal for how fusion opens SVG.
You can try extruding the object and deleting the SVG.
Use a .dxf instead and or doing the same thing as above.
Reproduces the object in fusion the only part that looks hard is the lions head.
Daniel Lyall
The Big Boss
Mach3 User
what is the best format to save a bitmap from Inkscape which will be imported into Fusion 360. There are several options in inkscape such as 12 or 14 dxf, different svg's etc. Does anyone know which one fusion 360 would do most easily without alot of editing? tyia
