Import Setups
Import Setups
TimKeij
Import Setups
TimKeij
Hi all,
Is it possible to import manufacturing setups?
I can copy a setup within a project but I don't seem to be able to copy it to a new project.
This is what I would like to do:
I have a test-part with the right setup (in the manufacturing model): contour milling, drilling etc. at for this part the right speed etc.
I have an assembly with simular parts. I would like to add this 'test-part' to copy the setup to the other parts.
So that in the setup I only have to re-click all the new contour lines, but that the speed and ramp, etc stays the same.
Is this possible? Or is there a better solution I haven't thought about?
engineguy
@TimKeij
A simple copy/paste will place the Setup in the new Document, you do have to save the new Document first and also select the new Body in the new setup, all the operations will show a Red icon but as you select each Pocket/Contour etc and re-generate the operation then you will be using the same tools and the same speeds/feeds in the new Operations.
Is this what you are looking to do ??
Screencast link added 🙂  https://autode.sk/3m0oklN
TimKeij
How easy life can be! 😌
 Thanks, that is what I needed. Missed the obvious.
