iMac using Fusion 360 needs to connect to older machines that use RS232 inputs
JonSchaeffer
JonSchaeffer
Anyone use an Apple computer to up load NC file to older Lathe that uses RS232 inputs?
Can I go and get cables that go from iMac USB and connect to the RS232 on the machine?
www.genesisprecisionaz.com
info@genesisprecisionaz.com
RandyKopf
This this is a duplicate post. @JonSchaeffer I don't have a MAC but did have the same problem with a PC that had no serial ports. Radio shack has a USB to RS232 cable that worked. My PC added it as a COM4 and I was good to go. The cable did not say it was for PC or for MAC so there is no reason it would not work. The Gigaware cable I bought was a USB to DB9 pin Serial Bestbuy has them and states they are compatable with both PC and MAC http://www.bestbuy.com/site/searchpage.jsp?id=pcat17071&st=usb+to+serial There are also cables that will convert from 9pin to 25pin if you need that. http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=432216 Hope this helps! Randy Kopf desktopartisan.blogspot.com
Randy Kopf
http://desktopartisan.blogspot.com/
If my post is helpful, press the LIKE Button If it resolves your issue, press Accept as Solution! Have a great day!
rklopp
I use a Prolific branded USB to to 9-pin serial adapter connected to a MacBook Air going through a null model (with some internal doctoring, as I recall) to talk to a 25-pin D serial connector on my old Deckel FP2NC with Dialog 4 control. I use the terminal emulator app "Serial" to talk to the Deckel. The communication is reliable at 2400 baud, less so at 9600 baud. I use 8-bit, no parity, and 1 stop bit with no traffic control. This is by far the easiest setup I have found for talking to the Deckel compared to several generations of old Windoze machines with built-in serial ports. The Serial app is comparatively idiot-proof. No more drinking around with COM port numbers or any of that drivel.
I have no problems sending the Deckel CAM output from the Fusion 360 post I have modified for the Deckel, and bringing g-code back from the Deckel for modification or archiving. (256k RAM only goes so far, after all.)
