Fusion Manufacture
if/then, logical AND, OR solution
2 REPLIES 2
infoXNDBJ
111 Views, 2 Replies
I have figured out the nested if/then branching for example
GewKern_D > 4.2 ? 1 : (GewKern_D <= 2.5 ? 0.5 : 0.8)
if thread diameter > 4.2 then 1 else nested if. it is a kludge for complex nesting because we use at least 5 standard tools...but it works
what I didn`t figure out so far is logical operations AND, OR, NOR. I have tried based on https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-76272551-3275-46C4-AE4D-10D58B408C20
((GewKern_D > 4.2) and (GewKern_D < 5)) ? 1 : (GewKern_D <= 2.5 ? 0.5 : 0.8)
Either there is an error in logic or Fusion360manufacturing extension doesn`t allow logical operations.
Any suggestions, please?
2 REPLIES 2
njdupreez
in reply to: infoXNDBJ
TL;DR: Use &&, ||, ==, !=, ! for logical and, or, equal, not equal and not.
If I use the following as the expression of a parameter it seems to work:
if(GewKern_D > 4.2 and GewKern_D < 5; 1; if(GewKern_D <= 2.5; 0.5; 0.8))
The syntax is:
if( logical_expression ; true_case false_case )
That's straight forward.  However using the same expression above, that works for parameters, to specify e.g. the Surface Feed setting based on the diameter yields an error stating that the expression can not be evaluated.  To get an expression to work use the following syntax:
GewKern_D > 4.2 && GewKern_D < 5 ? 1 : GewKern_D <= 2.5 ? 0.5 : 0.8
So basically use &&, ||, ==, !=, ! for logical and, or, equal, not equal and not..
Note that you have to click on the menu button and select "Edit Expression" to change the expression once you have entered it.
infoXNDBJ
solution for boolean operations in machining mode
&&	and
!	not
||	or
Above by statement would be translated into
GewKern_D > 4.2 && GewKern_D < 5 ? 1 : GewKern_D <= 2.5; 0.5; 0.8
