Fusion Manufacture
Idea: Save actual toolpath in a template
1 REPLY 1
Joshua.mursic
67 Views, 1 Reply
Hello, I am wondering if it is possible to save the actual toolpath inside of a template and then snap that toolpath to different regions on a model. This would be awesome for complicated features that are repeated on a model, I could just pick an origin point on that feature and snap the toolpath into place. The problem with templates on complicated features is that I have to reselect the geometry. Is there anything like templated toolpaths in Fusion 360?
1 REPLY 1
seth.madore
in reply to: Joshua.mursic
You can't save any actual toolpath geometry, just the toolpath settings.
If you have to repeat the same toolpath across many different areas of the part, you might want to try Pattern > Duplication.
Seth Madore
