Fusion Manufacture
ID Figure 8 Oil Groove
4 REPLIES 4
m_lamarca
192 Views, 4 Replies
Is there a way to, inside Fusion, program an ID Figure 8 Oil Groove?  (Edited to add) Using lathe groove tooling, such ID full rad groover.
It’s always been a fat finger g32 previously, so just curious if it can be done inside the software.
attached is a similar file, that I downloaded from the forums to look at and learn, but I don’t see any manufacture, just design.
4 REPLIES 4
seth.madore
in reply to: m_lamarca
How would you plan on doing this; what tooling and axis combination do you have at your disposal?
Seth Madore
m_lamarca
in reply to: seth.madore
Was planning on TLR/NR 3062L style ID groove full radius boring bar.
Lathe is live tool, XZC, no Y. Our actual part is 6” long, so live tool keyseat cutter isn’t a great option.
seth.madore
Oh, you want to turn this? That's....not something that would be supported in the software.
Seth Madore
m_lamarca
G34 and fat finger it is then….
