Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
I select geometry for engrave, but tool path only engraves part of the engraving, random
1 REPLY 1
dansjpm
216 Views, 1 Reply
When I select geometry for engraving, Fusion360 only generates part of the engraving tool path, I have 99 contours, about 65 percent of them receive a tool path, the rest do not, the toolpath generation is random and will change if I force a regenerate. I have restarted and reinstalled, with no luck.
1 REPLY 1
engineguy
in reply to: dansjpm
@dansjpm
It is not anything at your installation, it is not happy with the Multiple depths, that would be the "bug" I think, I also changed theMaximum Angle, because your design has many end of lines/arcs Fusion is trying to raise up at every join, seems better now and you can re-generate as many times as you like and it toolpaths all of it (I think) 🙂 🙂 🙂
Looks like you have some "cleaning" to do, there are toolpaths crossing previous cuts but I will leave that to you 🙂
Technology Administrators
