i need to know how produce gcode from a stl file using Fusion 360 Please help
Awesome-Tools
Awesome-Tools
Hello
I am new and just start to learn Fusion 360 - I am learning using the Fusion 360 Adoption but I have no clue how to do this.
I bought a stl file on ebay, I have a Shapeoko 3 XXL CNC and I also use GRBL v1.1 to run my machine
I am lost for days and decide to post here seeking for help and direction what step to take
plsase someone help me. Thanks in advance
Replies (16)
jodom4
Hey guitarelements,
Can you reply with the STL file you're trying to use? Also, please attach a Fusion archive file if you've got one so we can help.
Jonathan Odom
Community Manager + Content Creator
Oregon, USA
Become an Autodesk Fusion Insider
Awesome-Tools
Hello and thank so much for your replied and help.
This what I have been doing and I am still confuse and do not know what to do
The model i bought on ebay is a file stl format. I used Slic3r program and able to load the stl file, then generated the gcode for it. The stl file is approx 145.00 MB and the gcode produced by slic3r.org is 38.2 MB
- I load the gcode used GRBL v1.1 which connect to my shapeoko3 CNC,
I did $h the spindle went home ( top right corner )
then I jogged the spindle to the bottom left corner of the stock and set zerojob there.
I click on send (GRBL )
the spindle move from the bottom left corner toward HOME ( top right corner )
Then the machine trying to move very violent making horrible noise, i was freaking out and do not realize which way it try to move,  so I hit the stop switch on the cnc to abort the job
I really want to be able to learn and create this art work on my shapeoko 3 cnc. So frustrate so I search and found that Fusion 360 can help me to achieve what I am trying to do.
I am attaching the stl file and the gcode which generate by slic3r
I have no clues what is going on and so hopeless
I am trying to attach the stl and the gcode but it is not uploading it take for ever and not uploading
Awesome-Tools
trying to attach files but it is not attaching seems like the website is overload for attaching file
Can't attached stl and gcode do not know why but it not working
here is the few lines of the gcode generated from slic3r
; generated by Slic3r 1.2.9 on 2018-06-24 at 15:44:22
; external perimeters extrusion width = 0.50mm
; perimeters extrusion width = 0.72mm
; infill extrusion width = 0.72mm
; solid infill extrusion width = 0.72mm
; top infill extrusion width = 0.72mm
M107
M104 S200 ; set temperature
G28 ; home all axes
G1 Z5 F5000 ; lift nozzle
M109 S200 ; wait for temperature to be reached
G21 ; set units to millimeters
G90 ; use absolute coordinates
M82 ; use absolute distances for extrusion
G92 E0
G1 Z0.350 F7800.000
G1 E-2.00000 F2400.00000
G92 E0
G1 X0.000 Y-11.230 F7800.000
G1 E2.00000 F2400.00000
G1 X262.481 Y-11.228 E10.12152 F1800.000
G1 X265.698 Y-10.393 E10.22436
G1 X266.959 Y-9.512 E10.27195
G1 X267.155 Y-9.338 E10.28003
G1 X268.581 Y-7.542 E10.35100
G1 X269.342 Y-5.113 E10.42976
G1 X269.395 Y-4.298 E10.45502
G1 X269.397 Y204.272 E16.90846
G1 X269.373 Y204.832 E16.92579
G1 X269.215 Y205.851 E16.95773
G1 X268.359 Y207.980 E17.02869
G1 X266.830 Y209.689 E17.09966
G1 X265.528 Y210.489 E17.14695
G1 X264.989 Y210.727 E17.16516
G1 X262.473 Y211.223 E17.24451
G1 X-62.475 Y211.225 E27.29885
G1 X-64.653 Y210.857 E27.36718
G1 X-65.430 Y210.546 E27.39308
G1 X-67.333 Y209.266 E27.46404
G1 X-68.686 Y207.414 E27.53500
G1 X-69.257 Y205.687 E27.59129
G1 X-69.377 Y204.850 E27.61746
G1 X-69.401 Y204.277 E27.63521
G1 X-69.400 Y-4.302 E34.08890
G1 X-69.355 Y-5.053 E34.11219
G1 X-68.734 Y-7.261 E34.18315
G1 X-67.033 Y-9.455 E34.26904
G1 X-66.832 Y-9.624 E34.27718
G1 X-65.782 Y-10.349 E34.31665
G1 X-62.481 Y-11.231 E34.42239
G1 X-62.394 Y-11.231 E34.42506
G1 X-0.075 Y-11.230 E36.35330 F1800.000
G1 E34.35330 F2400.00000
G92 E0
G1 X-61.176 Y-3.003 F7800.000
G1 X261.171 Y-3.003 E11.97385 F1800.000
G1 X261.172 Y202.999 E18.34783
G1 X-61.177 Y203.000 E28.32173
G1 X-61.176 Y-2.928 E34.69343
G1 X-61.801 Y-3.628 F7800.000
G1 X261.796 Y-3.628 E44.70595 F1800.000
G1 X261.797 Y203.624 E51.11860
G1 X-61.802 Y203.625 E61.13117
G1 X-61.801 Y-3.553 E67.54154
G1 X-62.230 Y-4.253 F7800.000
G1 X262.421 Y-4.253 E77.58666 F1800.000
G1 X262.422 Y204.248 E84.03798
G1 X-62.427 Y204.250 E94.08921
G1 X-62.426 Y-4.255 E100.54064
G1 X-62.305 Y-4.254 E100.54439
G1 X-61.981 Y-3.819 F7800.000
G1 X-60.798 Y201.433 F7800.000
G1 X-59.609 Y202.622 E100.59646 F1800.000
G1 X-58.725 Y202.622 E100.62385
G1 X-60.798 Y200.548 E100.71466
G1 X-60.798 Y199.664 E100.74204
G1 X-57.840 Y202.622 E100.87158
G1 X-56.956 Y202.622 E100.89897
G1 X-60.798 Y198.779 E101.06723
G1 X-60.798 Y197.895 E101.09462
G1 X-56.071 Y202.622 E101.30162
G1 X-55.187 Y202.622 E101.32900
G1 X-60.798 Y197.010 E101.57473
G1 X-60.798 Y196.126 E101.60212
G1 X-54.303 Y202.622 E101.88657
randyT9V9C
slic3r.org is, as the name implies, a slicing program intended to produced code to be 3D printed, not  milled.
Maybe this video will help.
https://www.youtube.com/watch?v=GslfM22EDg4
Awesome-Tools
thank you for your help - i am going to watch and learn from this video, will come back to post the result - Thanks again for your help
Awesome-Tools
Hello
Sorry for the late replied, I have been sick and just get out from the hospital. I try to attach the STL file but it is too big to attach. please attach a Fusion archive file  - I do not know what this is - I am new with Fusion 360 and it is so confuse, is there a class for beginner absolute beginner for me to learn. Thanks in advance
randyT9V9C
Click File, Export, and choose Archive File *.f3d.
Awesome-Tools
Click File, Export, and choose Archive File *.f3d.   ------------ I am so sorry - where do I do this???
randyT9V9C
Awesome-Tools
Hello
I got home from the hospital due to surgery. I am not sure if I did what you instructed me correctly. pls see attached image - I believed I upload it to the cloud.05050.png
LibertyMachine
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
Awesome-Tools
I try to watch your video but it is almost impossible to see, it is so small and I can't see the texts  on screen to follow
HughesTooling
@Awesome-Tools After starting the screencast above did you enable full screen? As for attaching the stl you might need to add it to a ZIP archive, some file types are blocked be the forum software.
Mark
Mark Hughes
Owner, Hughes Tooling
Awesome-Tools
Hello
Thanks for your replied and help. I am trying to understand your question, but I am not sure if I understand. I am sorry I am not smart, I am learning the from the Academy here, maybe I need to go through every single classes to get familiar with the term and terminology so I can understand and go back from beginning to watch these lessons 2nd time, I am now less frustrate and making progress. This is the 1st time in my life I try to learn CAD/CAM no background about machinist at all. So I am learning the basic. I need to be patient and learn 1st before crying out. Thanks and have a great & safe Labor Day weekend and God Bless. I am not giving up on your instruction, I am going to try to do what you suggest to see.
Awesome-Tools
I am not sure and I am confuse - thanks
seth.madore
If an .stl file is being rejected from the forum, you will need to add it to a .zip folder.
Find your file in the computer, right click on it and select:
Seth Madore
