I'm looking for best practices to pocket out a shaker cabinet door
RedMonkeyMakers
RedMonkeyMakers
I'm creating simple shaker cabinet doors and I'm struggling with what would be the best way to cam so that it leaves the cleanest finish.
My first thought was use a 1 1/8" surfacing bit to hog out the large pocket area leaving .5mm radial stock
I could then come back with 1/8" endmill and clean up the corners and the edges of the pocket.
I'm really struggling to figure out how to do that though.  When I create a pocket toolpath for each of the bits, the 1/8" bit goes over everything again.
I've attached the file.  Anyone have a better approach to get a clean solution?  I'm pretty new to all this.
Replies (7)
matty.fuller
What you want is straightforward, the second operation to clean up the wall should be a 2D Contour, as attached.
That said, the 1/8" tool you've defined isn't long enough for the job, you'll see in the simulation that the shank collides with the part. You'll need a longer tool to machine this part, or use T1 and accept a larger fillet in the corner that you clean up with a chisel.
RedMonkeyMakers
OK I updated the depth in the example so that my bits don't collide.  The profile toolpath works but it leaves some bits...
See attached updated file:
matty.fuller
That'll be because the difference between the two tools is quite large. You can easily remove that material by adding roughing passes to the 2D Contour, but it will spend a fair amount of time cutting air.
The more efficient (in terms of machine time) approach would be to use Adaptive Clearing with Rest Machining - From Previous Operations turned on, so it just clears what's left after the pocketing operation. I've set that up in the file for you to take a look, with quite conservative tool engagement.
RedMonkeyMakers
Thanks for that. This helps very much. I wasn't aware of 'Rest Machining'. I'll have to do some research on the topic. Really appreciate the help.
programming2C78B
Just fyi but you can also do this particular one inside of 2D contour. It does REST machining off a theoretical tool dia without calculating actual stock from a mesh. Set it slightly larger then your face mill and it'll mill out just to corners
Please click "Accept Solution" if what I wrote solved your issue!
RedMonkeyMakers
I see that you can set the tool dia on the REST settings for contour as well. This forum is fantastic and I'm very thankful.
matty.fuller
Nice tip, I wasn't aware of that.
